Gauges for 1988 Evinrude 70hp 3cyl VRO
KJHiggins
Hi All
Gauges for 1988 Evinrude 70hp 3cyl VRO - Model: E70TLCCA
I'm looking for gauges for the above engine. A lot of the OEM gauges are now obsolete!
I'm looking for:
Tacho with harness - 174206 or 175354
Speedometer - 174458
Temp - 175412
Volt - 174097 or 175480
Trim - 175483 or 174663
Many thanks
Kevin
KJHiggins
Thanks Schematic
Can you suggest any good websites to buy from?
Thanks for your help.
Kevin
flyingscott
Hello you do not need a volt gauge for your motor most outboards don't have them because of the limited output you have a 6 amp alternator unregulated . You also don't need a temp gauge most outboards don't have those your controls have a warning horn .Trim gauge you can use any good aftermarket same with speedo and tach. The tach harness call a dealer a lot of them have used ones laying around plugs right into the control unit. My 2cents the only gauge you need is the tach a speedo can be replaced by gps which is much more accurate. A T/N/T gauge is a personal choice
KJHiggins
Thanks flyingscott
I have a harness on my old tacho, which I was going to cut off and re-wire if needed.
How do I check if the horn works for temp please?
I use Navionics, so speedo is not important.
Thank you
flyingscott
Ok your horn works 3 ways depending if your vro is hooked up and working. . 1 beep every second is no oil flow in the pump a beep every 20-30 seconds is low oil in the tank a solid beep is overheating. T/N/T is short for tilt and trim. To check the warning horn you need to short it out at the overheat sensor at the motor located in the head. I would get the factory harness for the tach no splicing involved just plugged in to the control box and go.
emdsapmgr
Bombardier dealers have access to an internal dealer network called Bossweb. In that restricted dealer network, Bombardier runs a website for all their dealers to post their dealership parts for all the other dealers to see. I did a quick check of all of your part numbers and found the factory has no stock on hand of any of these parts. However, their dealer network has new (leftover stock) on hand of each of your part numbers. At least 4 or 5 pcs of each, scattered at Bombardier dealers across the U.S. So, suggest you contact a local Bombardier dealer and have him run these numbers for you so that you can get dealer names and phone #'s. Call them up and give them your Visa card....
KJHiggins
Thanks Flyingscott and emdsapmgr
The harness attached to my tacho has power! But, my tacho is stuffed. I've cut the cables to free the harness to be able to wire the rest of my instruments.
I tested the T/N/T, volt and temp and they all work. I'll put them back in the console as I have holes for them.
I'll see if I can test the temp horn. The VRO is disconnected.
I'll check out the Bombardier Dealers for the tacho and speedometer.
Thanks for all your help, it's been invaluable.
Kevin
