I am new to posting on the forum, but I have been reading for quite a while.
I have purchased a used pontoon boat. The gauges in the dash do not work. The boat was in a slip at a marina and I was just able to purchase a trailer this past weekend and this was the first time I have had it out of the water. The speedometer did not work but I found that the pitot was missing when I took the boat out of the water. I purchased a new one and installed but have not tested yet. The Tach is an OMC system check tach and it is stuck at 6k out of 7k. All of the lights in the Tach System Check light up and the horn blows. The tilt gauge will move a little when the motor is raised or lowered but it is not correct. The volt meter is at 11 and when the ignition turns on pegs to 18+.
The fuel gauge is the only real gauge I care about working. I read a bunch of these forums and have tried a bunch of the troubleshooting items. The gauge seems to be working fine. The peg tests all seem to tell that the gauge works. I assumed the sending unit was bad. I bought one of the Moeller Electric Sending Units and replaced it. The thing is now that the gauge will never go below 1/2 a tank. I took the sending unit out and played with the lever and when it is all the way down, the lowest the gauge will go is 1/2. I checked the ohms at full (lever up) and it is 32.91. The ohms at empty gives me a reading of around 189.56 which I thought was low. Do I need to replace the gauge or is there some other problem I don't seem to be getting or understanding? Would appreciate the help on the fuel gauge and any of the other gauges as well.
Thanks in advance
Light
Thanks in advance
Light
