Re: Gauge lights
You know its NOT a ground problem because if it was, the gauges would not work. It is a power feed problem from the NAV/ANCHOR switch. Start there. Look for 12 volts into the switch and then check out of the switch. If the two lights work, then move on from the switch to the first light in the system. Since none of them work, I'm betting the first light connection is bad.
