Gasoline vs. Gas mixed with Methanol
trophyman
I raise this question because I'm noticing that many of the local gas stations now have a posting indicating that the gasoline is mixed with 5% Methanol. The sticker on my boat indicates that I should only use gasoline. I fill up at the local Hess station since my boat is on a trailer. What problems does the Methanol pose to an outboard engine? It burns fine in my Fuel Injected V8.
LubeDude
Re: Gasoline vs. Gas mixed with Methanol
5% isnt going to cause any harm. The problem with methanol is damage to the gaskets, and fuel pump, just makes replacing more often necesary.
BF
In snowmobile circles, what I've heard is that running a 2 stroke with alcohol mixed fuel is the almost (?) equivalent to dropping down a jet size. If you're jetted on the edge, then the booze blend can cause a running lean situation. Anyone heard anything along these lines with OB's?<br /><br />I think the cold weather makes sleds more susceptible to lean jetting situations.
ZmOz
It's probably ethanol, not methanol. Methanol is really bad for any engine that isn't built for it.
Realgun
Most engine can stand up to 10% Ethanol with little or no ill effects. However older carbs will be cleaned and a lot of varnish will be taken off the walls of the fuel tank and carbs leading to a possibly crudded up filter and leading to the engine getting little fuel as the carb and/or filter might get plugged up. Most of the newer fuel lines and rubber parts are made from ethanol compatible rubber. If not then they will just wear out faster.<br /><br />I would love to run my engine on ethanol or E-85 but in order to do that I will need to replace the fuel tank with a stainless tank. and they dont have a larger jet for my carbs as you need a 9:1 ratio as opposed to 14:1 with gasoline due to the Oxygen in ethanol.<br /><br />The reason I want to do this is that Ethanol will provide a better amount of power at a higher cruise speed.
twinsfan
I am not sure if it is the same in an outboard engine, but in my atv i find that if i let the gas sit without running for more than a month the needle in the carb will start to crystalize around it and runs rough until i get some seafoam into it.
