gasket sealing compounds
medic2051
I'm replacing my water pump, and the manual says to dip the screws in OMC gasket sealing compound. None came with the kit, is there a substitute I can use? How about grease? What about the "moly LUbe" packet that came with the kit for placing on the upper drive shaft splines?
Duck Loads
Re: gasket sealing compounds
I have used Permatex Aviation gasket sealer for this application on car and outboard motors and seems to work great. I small tub with the brush in the cap will last a very long time.<br /><br />Good luck,<br />Dauck L.
wayne h
Master Chief Petty Officer
remember to get the NON hardening kind
