Gasket..Glue or no Glue
Holy Shamolee
Well, i've decided to try the 2 carbs on my aq120b engine.
When I took the old intake manifold off, it was glued to the head. It was a bugger to clean the head, but it's done.
Now I need to know if the new gasket actually needs glue.
And if it does(and I hope it doesn't) does it go on the head side of the gasket, or the manifold side of the gasket.
robert graham
I use a light coating of marine grease on both sides of gaskets.....makes everything a lot easier at disassembly time.....in fact I re-use the gaskets when I can...
bruceb58
No gasket sealer needed. Torque per the spec in the manual.
Holy Shamolee
Well, everyone made my day.. It's going together without glue or gasket maker or anything at all.
Thanks.
