Gas???????????
jhang
HI peps,
I got a 67 evinrude 60hp any ideas how much gas i should be burning. I went on 6 gallon of gas in less than 1 hour is that even possible. How do we determine the gas usage on this motor? Is it burning too much excessive gas? Any tips much appreciate. Thanks
hidef
Re: Gas???????????
6 to 7 gallons an hours is about right if you were running at WOT.
archcycle
Re: Gas???????????
Fill with gas, start timer, run at WOT until you run out, stop timer :)
Outboards eat lots of gas at WOT. You just have to come up with a speed/throttle position that gets you from point a to b at the most efficient ratio of time to fuel.
boobie
Re: Gas???????????
10 % of the horse power at wot is what you'll use. 6 gal/hr is normal. Back off the throttle until the throttle plates just almost close and your timing is still advanced and that's where you'll get the best mileage.
Davem3
Re: Gas???????????
there are magnets installed between the speedometer and the gas gauge................ the higher the speed, the faster the gas says good bye.
but it is a lot of fun, though, huh???
