what gas to oil ratio should i use for my 87 mariner 40
Q quackaddic Cadet Joined Jul 29, 2010 Messages 8 Oct 4, 2010 #1 what gas to oil ratio should i use for my 87 mariner 40
B bigesox11 Petty Officer 2nd Class Joined Aug 30, 2010 Messages 136 Oct 5, 2010 #4 Re: Gas to oil ratio? Your always better off with more oil.
milehighboater Petty Officer 1st Class Joined Jul 28, 2009 Messages 235 Oct 5, 2010 #5 Re: Gas to oil ratio? bigesox11 said: Your always better off with more oil. Click to expand... More oil can lean the mixture, 50:1 means 50:1. You'll get enough variance with the less than accurate plastic measuring cup and the gas that blows back as you fill the tank too fast at the pump.
