Gas Tank Vent
Yankee30
I was wondering in my quest to find out what is causing the fuel restriction problem with my 150. I'm replacing the fuel lines and I check the vent tube from the gas tank to see if I could blow threw it. I was able to but blew out a lot of gas in the tube out the vent. Is this normal or should there be a check value in there? Also it is a 40gal tank do you think there might be another vent on the tank somewhere?
Thanks,
Jim
tashasdaddy
Re: Gas Tank Vent
normal. the vent hose is suppose to have a loop in it, so gas just does not slosh out.
