coopstar55
Thread starter- Joined
- Sep 8, 2010
- 11
I have an older closed bow 16 ft Jupiter and I am toying with the idea of putting the gas tank up under the closed bow in front. I currently use a 6 gallon tank but would love to upgrade to a 9-12 gallon tank. I thought that too it might help with weight distribution by putting it in the front. My only issue that is see is the amount of fuel line I will have to run. I currently have a 55 evinrude 2 cylinder on the boat. Will the motors fuel pump be strong enough to pull fuel the distance of most likely 17 ft of line? should I use metal fuel line for a majority of the distance? should the fuel bulb be closer to the fuel tank or the motor? Sorry for all the questions and if they are stupid questions, lol! I do not know a ton about boats so I am still learning. Thanks in advance for any help you can provide!
