Gas springs
cbass74429
This should be simple! But I want to make sure I do it right! I'm adding two gas springs, with hardware to,two storage compartments. The don't have any at this time. I made sure the brackets I bought would clear and work. I used the same size spring (I call them shocks) that is used on my main tackle storage lid! I'm curious if there is a set way to place them? Or formula to work out? I had planed on set them about 1/2 to 1/4 way up lid. Then set bottom where it will hold it open at angle I want. I know to make sure it will collapse and not bind.
Trivial I Know. But I looked at a new boat similar to mine yesterday and they didn't have it on rim (edge), but in center of lid to outside edge?
Thanks For All Of Your Help......
Davey Crockett Sr
cbass74429
Re: Gas springs
Thank You !!! I can get it with this I know. It's about what I thought would be.
Thank You Very Much Davey Crockett Sr
