gas oil mixture
want to boat
Have a 1975 25hp Evinrude, model 25502, need to know the correct gas / oil mixture ratio.... any help gladly appreciated!
javsam
Re: gas oil mixture
50 to 1.
1 quart of two stroke TCWIII oil to 6 gallons of gas.
Vic.S
Re: gas oil mixture
50:1 is near enough 1 pint of oil in 6 galls
Do the maths 8 pints to a gallon so 6 gallons is 6x8=48 pints
Threfore 1 pint in 6 gallons is 48:1 near enough to 50:1
For smaller quantities 50:1 is 2.56 fluid ounces oil in 1 US gallon
(or 3.2 fluid ounces per Imperial (UK) gallon)
Most of the world works in litres though
50:1 is then 20ml oil per litre of gasoline.
kenmyfam
Re: gas oil mixture
Slightly off subject but it sounds like this motor is new to you ??
Do yourself a favor and change the water pump impeller if it has not been done.
The other guys in the posts above have got the oilo thing covered.
Welcome to iboats.
