gas mileage?
drrtydog
My boat which is a 16 vhaul with an 80hp evinrude and my buddy has a 16 tri with a 90hp johnson i went through 2 tanks of gas to his 1 his motor is like a 76 or something and mine is a 67. This normal?
Re: gas mileage?
Depends on a number of things. First, you didn't say how far you went on those two tanks or how long you ran or how fast you ran. You have 80 HP, He has 90 HP. How big are your tanks, and how big is his. How fast did you run and how fast did he run. Your engine will burn roughly 8 - 9 gallons of fuel per hour at wide open throttle. His 90 will burn 9 - 10 gallons per hour at wide open throttle. His boat will probably burn less fuel at the same speed as yours because he does not have to have the throttle open as far as you do to maintain the same speed. In a nutshell, you are comparing apples to oranges. You don't have comparable boats. Those older engines were not economy champs. I have a 17 foot walleye boat with a 75 Merc. I also have a fuel flow monitor and at wide open throttle, two aboard, full live wells, etc., at wide open throttle the engine burns 7.5 gallons of fuel per hour.
drrtydog
Re: gas mileage?
we both have 6.6 gal tanks and we both were running around the lake the same. When both mine were empty only enough in one to get back to dock. We took his out tubing for half hour on still his first tank then he had to switch after that. That is a drastic difference. The orig prop is alot different then the one on the boat. So if a poorly matched prop was on couldnt that give me the poor gas mileage? The orig prop has a chip out of one of the fins.
tashasdaddy
Re: gas mileage?
you could be under or over propped, but i doubt it would make that much difference. sounds like you have a fuel leak somewhere, also check your spark and compression. what is the weight difference in the boats.
drrtydog
Re: gas mileage?
well had the orig prop rebuilt and took the boat out with 4 adults and tubed the whole time 4 hours on the same tank of gas.
