gas in oil
hodsyA
I have a 1990 omc 3.0L cobra the engine gets gas in the oil. I am talking about liters of gas. the engine has been out of the boat and been electro tested and rebuild still the same problem.
Don S
Re: gas in oil
Replace the fuel pump.
AZSenza
Re: gas in oil
The fuel pump has a diaphragm in it, fuel on one side oil on the other.
AZSenza
Re: gas in oil
well, it it were a jet engine I'd say your fuel heater/oil cooler was leaking but on a gas mechanical fuel pump engine, thats the only place the two can come together. Does it start ok? It's possible that you have a needle stuck in tha carb and when you shut down its dumping excess into the cylinders??? But that would show up as a hard to start/run
Gary H NC
Re: gas in oil
That much gas getting in the oil it's about 99.9 percent a fuel pump problem...
No way that much fuel is getting past the rings in the cylinder and it still runs..:confused:
Don S
Re: gas in oil
Not with the engine running.
Re: gas in oil
Ayuh,... Right where it says OMC parts at the top of this page...
a70eliminator
Re: gas in oil
All I can think of that hasn't been mentioned already would be the carb overflow return line to the fuel pump being hooked into manifold vacuum somewhere and it's pulling fuel out and into the crankcase.
Don S
Re: gas in oil
Even if it was dumped directly into the intake manifold, with the engine running it would still be sent to the combustion chamber and burned or flood the engine.
If the engine wasn't running, the fuel pump wouldn't be pumping so there is no way in ell you are going to get liters of gas into the oil.
