Re: Gas flow?
Just my guess as to what's happening...
When you start a motor that is cold, it revs up because it at first runs off of fuel from the prime start (choke) system.
Then it switches over to running off of the idle circuit of the carb/s, and drops back down to idle speed. When it drops back to idle speed, it will stall if the motor isn't warmed up enough. Once you do this a few times, the motor will have warmed up enough to stay running at idle speed. You can test my theory by doing the following... Start the motor and increase the throttle ever so slightly (in neutral of course). Then let it run for a few minutes so it warms up. During this time, it will not drop back down to idle speed because it will be running on the low speed carb circuits, which will give it more fuel than the idle circuit would have. After a few minutes of running, shut it off and then restart it without increasing the throttle. If it stays running, then this may be your problem.
If you find that this is the problem, it could be caused be several things. Perhaps your starting method is wrong. Do you prime it first (by pushing the key in while starting it), perhaps the thermostat is faulty and making it drop back to idle speed before it is sufficiently warmed up to stay running, perhaps idle speed is simply set too low.
I would read more about the prime start system to understand it. There is a red lever on the carb that may help make it run on the first start. It has an on, off, and emergency setting. It is connected to a thermostat via two wires that come out of the top of it. Read more about it to learn what it's all about.
