Gas cut off for 4hp Evinrude OB
Status
Not open for further replies.
mikemarcelle
I have the above motor with a plastic piece on the end of the metal bar that cuts the gas on or off. That plastic piece, which is forked, is broken. where or does anyone have that piece that I can replace or any idea's on how to fix this so that I don't have to keep taking the shroud off every time to turn the gas on or off? Thanking you in advance, Mike.
Joe Reeves
Re: Gas cut off for 4hp Evinrude OB
What's the model number of that engine?
mikemarcelle
Re: Gas cut off for 4hp Yamaha OB
Sorry but the motor is a Yamaha 4 HP with forward and reverse with a built in gas tank. I can't read the model # because the paper label is worn. It is the fuel cut off that ithe plastic piece on the end of the shaft is broken and won't turn the valve so I have to do it by hand. Mike.
Mas
Take it to a dealer...they'll help you ID the replacement part.
MAS
tashasdaddy
suggest you post this in the Yamaha forum, with correct info.
Status
