gas coming out of waterpump
hope2cwater
I have a chrysler 55hp w/alternator ;do not know year-70's. The model # is 55771 and the serial # is 10091. I have not had motor running. While trying to start engine it ran for a couple of seconds twice.
Then I noticed gas coming out of water pump housing area and also out of water pump intake port... I am guessing I got internal problems!?!
any ideas? Thanks!
eurolarva
Re: gas coming out of waterpump
Hello welcome2cwater and welcome to iboats. Your motor is from 1967. What you are seeing is fuel and oil mix that is not burning draining down the motor leg and exiting out of the lower unit. This is real common on outboards that have trouble starting. Even though the motor is not starting the fuel flow is still going to the cylinders. Also that motor does not have a recirculation system. Instead of having normal puddle valves that reclaim the fuel it also drains down the motor leg. When gas hits a hot engine it vaporizes and then settles to the bottom of the cylinders. You will notice on the port side of your motor two fuel hoses on the lower cover that go into a Y valve then go to the kinpin. This fuel is dumped back into the lake. I cut a hole in my cover and connected a bottle to my cowling to prevent this. After about 1972 they were redesigned and started reburning this fuel.
hope2cwater
Yep, I see now the gas drains out the bottom of engine. Whew; I thought the worst! I tried starting again and it backfired a couple times but did try to start... Sounds like timing is off; so I popped off the flywheel and sure enough the key way is sheared! Now; Does anyone know where to get one?
Also are you sure of year? Thanks again...
eurolarva
Positive on the year. 1967 was the only year that models with 2 digits had 5 numbers. 1968 and 1969 only had 4 digits like 5587 then they went alphanumeric starting in 1970 with like 557HA or 554HA. The flywheel key number is 28-F92498. They cost about $8 and you can order them from Mercury. When you get it back together you need to get 80 foot pounds on the flywheel nut. If you dont get it that tight you will have a strong chance of shearing the new key.
hope2cwater
Thanks for info. I picked up a new keyway at the boat shop today; yeh! He had one in stock! Put it back together and it fired right up! Seems to run nice and smooth and squirts out good water. I have another question but I will start a new thread. Thanks again.
