Gas and Spark to Plugs won't fire.
eyeguy2009
Hello everyone, I've got a 77 85 Johnson that I recently purchased. Cleaned carbs and new plugs. It fired up after that. However, I noticed that when engine is running at idle left side two cyls when you take off plug wire's aren't sparking, only right side cyl's. When you put it in forward and rev engine it "catch's" and run's on ALL cyl's. After turning it off it would fire back up quickly. Now, nothing. I pulled each plug individually and turned over moter and there IS spark on the plugs, each. It's a crap shoot. So, today I pulled the carbs again and made sure it's not the float's. Put carbs back on and still won't fire. Gas and spark are there but what else should I be looking for? Any suggestions would be great, thanks.
eyeguy2009
Re: Gas and Spark to Plugs won't fire.
It's alive..pulled gas lines off both carbs and pumped bulb on tank and flushed it out..ran it for about 30 min at diff speeds and purs like a kitten..lol thanks
