Garmin Depth Finder
MMSnablo51
I recently purchased a new Garmin Depth/Fish Finder/GPS. I have a 2003 Cobalt bowrunner. Can the sounder that is used in the Cobalt from the factory be hooked up to the Garmin and work or will I have to install a new dual frequency transducer.
Barnacle_Bill
Re: Garmin Depth Finder
You have to use a transducer made to work with the unit you bought.
gonefishie
Well, if your old xducer is a Garmin and the connector fit then they'll work.
Boatist
If the transducer in your boat is 200 Khz you can use it but will need to wire to the correct plug. The transducer that are pre mounted in some new boats I think will work with almost any 200 Khz units but check with the boat manufacter to be sure.
