gm280
- Jun 26, 2011
- 14,605
Thanks for the tips! I'll look into that stuff and see if I can make a spreadsheet of costs etc. I wasn't sure if I'd need new ignition set up or not under the flywheel. Probably an alternator and rectifier etc too.
Quick question since our motors are almost the same set up, does yours have bolt holes on the clamp bracket to bolt the motor to the transom? Or are these motors supposed to only be attached to the boat by the two clamps?
My '76 40HP Johnson used the screw clamps at the top area but also has two lower holes for bolts as well. Look at the clamping bracket to see if your's does as well. Probably so if I am thinking correctly.
As for the ignition system, there are probably the exact same. So I don't see any need to change that. The alternator is located under the flywheel and outputs via three yellow wires. Those three wires goes to a rectifier and then to the battery. There is no regulator on mine. And the rectifiers are available everywhere. Nothing unique. They used that same configuration for a lot of their engines.
If you don't already have a manufacturer's engine specific HP, year, model shop manual, you need to buy one. It explains everything about your series engine and probably explains the hand start version as well as electric start version. I know they cover both in my manual. That way you can see the differences and parts needed as well. And there are lots of break downs or parts and wiring and schematic diagrams and whatever you ever wanted to know about the engine.
As for the low speed plastic screw, yes that is located by the throttle handle slightly under neath. If your is bad, they still are available as well. It should be plastic (nylon) with a metal button at the very end.
If you want a tach wired up, you will need to have an alternator and the rectifier. Because the tach output comes off one of the pre-rectifier connections from the alternator. And that wire is usually gray and attaches to the rectifier where the yellow wires attach from the alternator but only attaches to one of those yellow wires.
Hope that helps a little. :noidea:
