hardwater fisherman
- Mar 19, 2010
- 1,725
When I converted mine to electric start I only hooked up the charging system because it was on the donor motor. And anyways it is only a 5amp charging system. So a motor in good running condition along with a good battery you dont need it. I use a small group 24 marine starting battery and that is plenty. As far as the clamps go if you can get them tight and lock them together it will be ok. On mine the loops on the end of the clamps are broken so I could not lock them. I bolted mine because they would not stay tight. And to help to prevent theft.
