Gap between prop and lower unit
blusporttrac
when i got ready to removed my prop to check the numbers on it, it seems to have approx 1/4" play when tightened all the way down is this ok?
ry%3D400
ry%3D400
sublauxation
Re: Gap between prop and lower unit
I'm no expert but looks to me like you're missing a thrust washer or something on the back side of the prop or it just plain wasn't tightened down enough. I think they should be torqued to somewhere around 40lbs.
blusporttrac
does anyone have a parts break down that i can look at to see if im missing something?
usskydvr
What Model/Yr engine? If your prop shaft is moving that much then you have a lower unit issue. If the prop only is moving then it is a thrust washer issue.
blusporttrac
Thanks guys! Its just the prop that moves. its a 1997 force 90hp elpt. My prop setup is a little diff then the link supplied above. the piece between the prop and nut sits on top of the prop and not into it. anyone have a site to pick up a thrust washer?
usskydvr
There were several different implementations of the FloTorq hub..see pic.
Also there is the standard hubbed prop setup. see pic
Which do you have?
cribber
I agree that just looks loose. Pull the cotter pin and check the prop nut for tightness. Make sure you have a spare cotter pin on hand. They can break...
sethjon
ry%3D400
ry%3D400
Before you put the nut on, do you see any spleen sticking out? If not you are ok. If you do, then you need a spacer before the nut goes on.
