callmecrazy
Thread starter- Joined
- Apr 28, 2011
- 6
Hi,
Just acquired an 80's gamefisher 1.2 (tanaka TOB-120) and I have a few questions.
The motor runs with the throttle lever in the 'start' position with the prop spinning. But when i push it to 'stop' the motor shuts down. So there's no way to run it at idle without the prop spinning. So, is this normal? is it an idle adjustment, throttle adjustment, etc..?
Second, The carb float keeps getting stuck. It happens usually within a minute or two after starting the motor. I've taken the carb apart and cleaned it well several times now. There is a little spring thingy shaped like a C that pushes a needle valve. the needle is apparently not seated on the C-spring thingy (whats it called?) correctly. I've messed with it a bit, and every time I think its working, it happens again.
Third, I want to get a spare prop and shear pin, just wondering if it would make any difference to put a 3.0hp prop on the 1.2?
Thanks
Thanks
