Gamefisher 9.9
Jwslauson
I think this motor is a force/Chrysler im not sure of the year. The model number is 225.581994 and serial number is 5898. Im not getting any fire to the ignition system. Going to try to pull the flywheel of tonight but there are no bolt holes for the puller. What is the best way to pull it? also are there any replacement ignition systems? TIA
Nordin
I think but I am not sure those engines had either the BIM ignition system or the 300-850899T system.
Both are N/A but there is a replacement kit for the BIM system.
It is a aftermarket system from CDI partnr. 116-2379, uuhh 250-260 dollar.
Jwslauson
Thanks for the reply , I did find that kit on ebay for 170ish , has anyone had good experience with this kit??
fishrdan
I've had that kit on my 7.5HP Force (same as 9.9 or 15) for 4-5 years and it works fine.
Don't remember how I pulled the flywheel....
jerryjerry05
I believe once you remove the top nut, the holes for the puller are under it,
