Gamefisher 15hp eskra
Dbswdd
I need to find a repair shop in the chicagoland area that he works on gamefisher.shift mechanism needs a special screw, and motor could use a tune up. Last time ran fine til the screw fell out, and I lost it in the lake. I live in the western suburbs of chicago email dbswdd@gmail.com
narwhals
Re: Gamefisher 15hp eskra
most of the eska were tecumseh engines and parts are still obtainable through many small engine places that are knowledgable on tecumseh engines. your model # and serial # are helpful to track down parts. sears parts look up can usually be helpful in obtaining part numbers if you have the right model #'s. most carb parts are contained in a standard rebuild kit "float,needle,seat,bowl gasket" pump element is part #630953 which can be cross referenced to an oregon part #. hope this gets you going in the right direction.
narwhals
you refer to a shift mechanism screw that fell into the lake , is this in the upper head area that connects the shift rod to the linkage or is this in the lower unit? some units use a press pin to hold it in place in the upper area which can be located at your local hardware store or napa autoparts. if you post your model and serial # i may be able to give you more info.
