gamefisher 15 hp
tigervet
Is there any way to add a tale tail to a 1996 gamfisher 15 hp . The outflow is thru the thermostat on the center back of the motor and very inconvenient to see if water is flowing ..... stupid design .. thanks
tigervet
Re: gamefisher 15 hp
Asked and answered .. drilling a small hole in the thermostat housing laterally to accommodate a small piece of rigid plastic hose , then adding a vacuum hose fitting stepping down in diameter to up the pressure produces a fine stream of water that can be seen at a glance without having to crawl out the back of the boat to view.. I don't understand why chrysler of force, or whoever built the thing, would design something so important so crappy. I will try to post pictures for any one interested if I can figure out how.
fishrdan
I'd be interested in some pics of the tell tale mod for the small Force outboards,,, or a link to the thread where you found the info. I have a 7.5HP Gamefisher/Force and am looking to do the same.
tigervet
I will try to get pix this evening and post them. Its really very simple.
