galvix
mike prince
I have seen several references to galvix (probably spelled wrong) but no mention of where to buy it. Also exactly what is the proper way to use it?
Thanks for your help in advance.
Mike
Woodonglass
Re: galvix
I assume you have an aluminum boat, and are refering to the product Gluvit. It can be purchase right here on iBoats or from any reputable Marine product dealer. It is use to seal the seams and rivets of your boat. Usually on the inside but can be used on the exterior as well. It IS an epoxy product and thus has NO UV protection so you will need to either paint it or provide some sort of protection from the sun for it.
I'm just sayin...:D
mike prince
Re: galvix
Thanks for the come back. I picked up on the proper name and spelling in the post after mine last night.. He got lots of replies which I read and will use that info. Thanks again.
