Try that some time with copper and aluminum and get back with us on how well it worked for you.
Hmmm,.... Should I say that nothing in OUR lifetime will happen?
What am I missing here? Remove the electrolyte and you won't have galvanic corrosion.
Toss a piece of aluminum flashing on top of a piece of copper flashing in your dresser drawer and see how fast the aluminum corrodes.
Zinc is even "less noble" than aluminum. Almost every penny in all of our pockets are copper on a zinc core, no big corrosion issue there.
Edit:
Better example- This is why you don't need 'zincs' or anodes on "trailer boats". No electrolyte no galvanic corrosion.
Galvanic corrosion is a specific type of corrosion consisting of dissimilar metals in an electrolyte. Another specific type of corrosion is "stray current corrosion", which results from improper wiring on either a boat or (typically) a pier at a marina. 'Zincs' offer no protection for stray current corrosion. And then there is just plain "oxidation" which is corrosion that simply takes place in the presence of O2.
