Gale 3D13V parts
Sodiumhaze
Hello,
I've just recently acquired a Gale 3D13V (1956 3hp single) sold here in Canada through Eaton's as a Viking. I'm planning on restoring the motor for use on a flat stern cedar strip canoe that I'm working on. I have the repair manual for the motor but, the part numbers listed do not correspond to any OMC parts, that I can find reference to. I know Gale was a subsidiary of OMC until it's closing in '63(?) and would expect that there is a master list that cross references the Gale part numbers with other OMC parts, as the Johnson, Evinrude and Gale products were all being built out of more or less the same parts bag. If anyone out there has any information it would be appreciated.
Thanks,
F_R
Honorary Supreme Mariner
If the part is the same as J/E, the part number is the same. The Gale 3 is not the same as a J/E 3
F_R
I have a few of them.
Sodiumhaze
OK, Thanks F_R. I know the internals of the Gale 3 are different then the J/E 3.
As I'm sure you've gathered, I'm a new to these old motors and am just starting to learn. I actually got into these motors because my father gave me an old 1958 JW-14 that he'd had in his basement for decades. I liked the 'look' of the motor and when I opened it up I fell in love with the simplicity of design and apparent ruggedness of construction (something lost in modern machines) I'm in the process of going through that motor, as well, and am finding parts, with few exceptions relatively easy to locate. Once the full restoration is complete on that motor it will be going on the back of an 18' Y-Stern cedar strip canoe I'm constructing.
The Gale is a new acquisition and the part numbers just were't jelling with the remainder of the J/E bits and bobs out there. I wasn't sure if, like with many other manufacturers, parts on the Gale product were issued different numbers then their equivalent part on a J/E (If you've ever owned a FORD and the comparable MAZDA you'll know what what I mean). So you've cleared that up for me.
Thanks again. I'll continue my researches.
RCO
The ignition parts are standard OMC, the carb is a Tillotson, and most seals and bearings can be matched up at a good auto parts store. If you ever need hard powerhead parts like pistons is where you start to run into problems. I do like Gale motors. I have owned several from 3-40 hp. I am in the process of restoring a 56 Buccaneer 25 that has been in the family since new.
