Re: Galaxy 17ft stringer & floor
Peter- My stringer layout seems very similar. I am leaning toward epoxy since opinions seem to indicate it is much stronger and more waterproof. As you can see from my pics, I left enough of the good old floor around the edges to have something to glue and screw the new floor to. Will need to use 3/4" spacers on the stringers since the new floor will be 3/4" higher. jfc092- What did you do about flotation foam. Looks like you didn't use any. I am undecided about putting foam below the new floor since it will just trap water. Anyone know why Galaxy used an untreated plywood form, which has totally disintegrated, to outline the engine well which is molded into the floor and sits above the hull. The bilge pump is in the engine well and any water that gets below the floor stays there. The front motor mount sits on the floor of the engine well supported be what looks like a 2X6 fiberglass cross member and is rock solid. I suspect the untreated plywood, encasing the engine well was used to form the engine well and was not intended for structural support. If it was they couldn't have expected it to last long.
