Re: FYI - SAE J557 standard for Plug Wires
Elk Chaser,<br /><br />The Code of Federal Regulations that mentioned plug wires and SAE J557 was updated in 1999 with no mention of another standard. <br /><br />Checking things out I came across this about SAE J2031 that was interesting:<br /><br />The current SAE standard for high tension ignition cable is titled J2031. In order to claim that a product meets the J2031 standard, the product must pass a series of analysis tests. <br /><br />Ignition cable is mainly tested for its ability to consistently deliver high voltage while maintaining its physical integrity. During testing a wire sample will be baked (48 hours at 220oC, 428oF), frozen (4 hours at -40oC, 40oF), set on fire, dunked in hot oil (48 hours at 90oC, 194oF) fuel or salt water, then subjected to acute physical stress by tight winding around a mandrel or by suspending a 50 pound weight. Cable jacketing is inspected for swelling, streatching, cracking or splitting while resistance or capacitance values are checked at intervals. High voltages ranging from 15,000 to 35,000 volts are applied to the cable, in some cases for as long as eight hours (Corona Resistance Test), in order to check for dielectric breakdown. <br /> <br /> One test, the Accelerated Life Cycle, compresses virtually all other tests into one sequential battery of abuse. It shows specifically how durable a cable must be to claim it meets SAE Standard J2031. In the Accelerated Life Cycle test a wire sample is wound around a mandrel in a specified manner and subjected to five tests, beginning with the salt water resistance test and ending with the low temperature resistance test. In each test one or more stressors are applied to try and "break down" the cable. <br /><br />To pass the Accelerated Life Cycle test, a test sample must withstand 60 hours of extreme temperature fluctuation, .32 1/2 hours of fluid immersion and 2 1/2 hours of applied high voltage (15,000 to 20,000 volts depending upon cable diameter). <br /><br />This represents almost 95 continuous hours of stress (nearly four straight days) in just one test. In total, there are 13 tests that make up the entire SAE J2031 standard.
