fuses
recman84
I have a 2007 Tahoe Q6 SF. when we bought the boat I did not receive an owners manual. I know my blower fuse needs to be replaced but I have no idea which fuse it is? I also have a trolling motor that came with the boat that is not working. Is there a fuse that could have possibly blown for it as well? The battery for the trolling motor is fine so I know that is not it.
Silvertip
Honorary Supreme Mariner
Re: fuses
If you don't know which fuse controls the blower, turn it on and pull fuses until the blower quits. That would be the one. For the troller, there should be a circuit breaker rather than a fuse located on or within a few inches of the positive terminal on the trolling motor battery. But some folks installed a fuse so it would be in the same location. Check for power at the trolling motor receptacle. If there is none, there is a wiring issue between the receptacle and the battery. If there is power, check the plug itself. That's as far as we can go because you failed to indicate what make, year and model of trolling motor you have. They are not all alike.
recman84
Re: fuses
thanks for the feedback. It is a motorguide 2007 57 thrust. I also have a depth finder attached and it does not come on either which made me think it was a fuse. I had an auto (turn off switch) on it right next to the positive terminal but I had them take it off cause it kept tripping everytime I went out.
Silvertip
Re: fuses
That "auto turn-off" switch was a circuit breaker and it was either two small for the current load or there was a wiring issue. So are you saying there is now currently no circuit protection? If so, you are risking a fire. Sort of like sticking a penny in your home fuse box. Fuses and circuit breakers are there for a reason.
