Fuse
jakedaawg
Too aid diagnosis I get a little circuit breaker and wire two spades on it. Put in place of fuse. Disconnect everything I can and then plug back in one at a time to figure what circuit the short is in. Trim and tilt, start solenoid, wire harness, etc...
boobie
I used to use an amp meter. That way I could keep an eye on what was going on.
Crosbyman
amp meter will allow high current flow and things and wires to burn up...while showing the amperage is high !!!
disconnect all loads first !!!
