Fuse problem Johnson 70 hp
Gary6124
I have a boat with a Johnson 70 hp motor that is blowing the main fuse after we get it out going in the water a good 15 to 20 minutes out
F_R
Honorary Supreme Mariner
Gotta be something shorting out. Hard to relate it to time or temp. Even harder to guess what it is. There aren't many things being supplied by that fuse. Unless somebody wired boat accessories to it, such as a bilge pump. You aren't supposed to do that.
Gary6124
I haven’t checked the ignition also the solenoid is hooked up to that fuse also
F_R
You don't give us the luxury of a model number or year. But yes the pull-in coil in the solenoid is supplied by the fuse. It would be extremely rare for that to draw that much current. Other typical things supplied are hot horn, and tachometer.
EDIT: Wild guess deleted. That was backwards thinking
