iceman3500
Thread starter- Joined
- Sep 25, 2012
- 2
I recently purchased a 1987 Carver 3207. I want to put some 12 volt audio/video and probably a 12 volt lighter plug in the main salon. What is the best way to route the wiring? I was thinking of a fuse block/bus bar combo in the engine bay and then run all the + and - leads to that rather than everything separately back to the batteries. Some leads need constant power and some need switched power for the head unit. Any thoughts on that? Are fuse block/bus bars capable of handling the heavier guage wires needed for a power amp?
I'd like to do the same to the bridge eventually running a separate stereo up there and powering a GPS chart plotter. I would assume I could do the same sort of layout up there in order to keep the wiring fairly simple and neat?
Go easy, I'm still learning and electrical is not my strong suit by any means.
Thanks
Thanks
