wecoyote
Thread starter- Joined
- Apr 25, 2008
- 19
Noticing that one of the riser bolts was missing I took it off. One bolt stripped out, one loose and going (both front short ones). Removed the riser, and no gasket. I filled exhaust at riser flange with water (yes the water jacket
), and it held it for half an hour. Next day top it off ( a tablespoon missing ) and direct my cutting torch down the exhaust ports to warm it up. Water and exhaust warmed up. Water still staying there, and cranking it over does not spit water from the plug holes.
So. Maybe I'm getting lucky. This weekend, new timing belt plugs and wires. New gasket for the riser (why do people let their boats go to cr*p for a $7 gasket, and their floor along with it for a $50 tarp ) but I digress.
Obviously water would have gone into the exhaust from the riser joint, my question is this. The riser about 5 inches in is corroded through from one exhaust passage to the other, and not (that I can see) into a water passage. Should I leave it, or try and find this hard to find (new or used ) part?
Thanks to all, and be sure to drink Corona this weekend.
Coyote
Coyote
