Funny Float Needle
thatone123
Banned
I took apart a circa 1970 Evinrude 18 carb and found a flat float needle? I have never saw one as most are pointed. Could the point have worn or broken off? Or are some models this way? They make a distinction between 1968 models and 1969-70. Wondering if this was an experimental carb or what? The motor ran but did not idle and I am wondering if it was because the float bowl would hold no gas as it leaked out because of this. I have ordered a new carb kit with a pointed rubber needle and new brass fitting for the needle.
Nothing experimental about it at all.--------Perhaps someone put that needle in a strong cleaner and did not realize they destroyed it.-----Install the carburetor kit and you will be good to go.
thatone123
Banned
GREAT, that is the answer I was looking for. I figured since it was called a "needle" that was the case, but it is very good to get an opinion and factual answer!!!
Faztbullet
Used to be a company called Viton Marine that made flat tipped no flood needles. Used a higher float setting and flowed more fuel at WOT. Installed a ton of these in V-6 and inline Mercs back in the 80's.
thatone123
Banned
Do you think one of these could have been put in this motor? I work on outboards and this looked kind of stock to me as the flat rubber did not look rotten, broke or worn. There was also no rubber residue, broken pieces and stuff like you see in water pumps. The metal needle also looked thicker than usual with a hexagonal shape.
thatone123
Banned
I changed out the needle and brass needle holder so we shall see how she runs. I am pretty sure the flat needle was a add on assembly as there was a raised flange at the hole so that the flat needle would close completely.
