SnappingTurtle
Thread starter- Joined
- May 4, 2008
- 1,251
New 4-stroke 4HP outboard motor!
We have finished outboard motor, it has EPA certificate, if you are interested!
Features Specifications: EPA certified 4-stroke 4HP outboard motor
OUTBOARD 2.5HP
ENGINE TYPE OTTO CYCLE:2 STROKE
BORE X STROKE: 43 mm x 38 mm(1.693x 1.496)
DISPLACEMENT :56 cc (3.417 CU-IN)
NO.OF CYLINDER: 1
FULL THROTTLE: 5,600 (rpm)
STARTING MANUAL:RECOIL STARTER
COOLING FORCED WATER CIRCULATION :BY PUMP
ENGINE LUBRICATION 2 STROKE O/B MOTOR OIL MIXED WITH GASOLINE
FUEL TANK: 1.2 LITER (0.32 GALLON)
CARBURETOR: 13 mm VENTURY,FLOAT TYPE
IGNITION CAPACITOR DISCHARGE IGNITION : (C.D.I)
SPARK ADVANCE VARIABLE WITH THROTTLE LEVER :
SPARK PLUG NGK B6HS or CHAMPION CJ8Y
EXHAUST UNDER WATER
GEAR RATIO :12:25
GEAR CASE OIL :GEAR OIL SAE W80/90,40 CC
SHIFT CONTROL SWIVELLING :360 degree
TRANSOM HEIGHT :370 mm (14.6)
PROPELLER 3 BLADEx186 mm(7.3) DIAx100 mm(4) PITCH:L
TRIM 4 POSITION
NET WEIGHT :11.8KG(26.0 POUNDS)
OUTBOARD 2.5HP
NO.OF CYLINDER: 1
EXHAUST UNDER WATER
GEAR RATIO :12:25
TRIM 4 POSITION
