fuel
spring1802
Is it possible for boat to use gasoline or diesel?.Plate on boat engine floor area indicates this. MCM carb 5.0l LX 305 cid 230 hp Maxum boat. I looked at fuel system section in manual,it says nothing about this which I have never heard of -either fuel being used.
Don S
Re: fuel
No, the engine is gasoline only (From the factory).
That plate wasn't attached to the fuel tank was it? Indicating it could be used for either.
Post a picture of the plate, never seen one that said that.
Re: fuel
Ayuh,.... Welcome Aboard,... Gasoline, 'n Diesel are Not interchangeable, in Any motor, it's 1 or the other,....
'n yer's is a Gasoline motor....
I too, would love to see that tag yer talkin' 'bout...
spring1802
Re: fuel
I will post the tag picture but I now realize it is a rating for the tank to use either depending on the engine.
agallant80
Re: fuel
I was under the impression that some military motors could run anything, Gas, Diesel, JP etc.
Don S
Re: fuel
Those are special built outboards, not Mercruiser 5.0L V8 Chevy motors.
