Fuel Vent
jfjohnson
My 2021 SeaFox Commander 268 is not taking fuel at the pump. Vent hole in the fuel cap is full of fuel. I believe the 2021 268 has a carbon-vapor canister vice a vent valve. Assuming this is a problem with the vapor canister. Couple of questions.
1. Do we think it's the canister and not some other fuel line problem?
2. Where is the canister located on the 268? Not sure what it looks like.
Owners manual is zero help on this one.
Thanks.
dingbat
Is your boat outboard or onboard powered?
Outboard powered don’t have fuel canisters
Boats are notorious for having the fill on the lowest portion of the fuel tank while in the water.
More than likely you filled the vent (trap) with fuel. Remove and blow out with compressed air
