I did something really stupid this weekend, I have a 40hp 63 evinrude, which was on a 15' fiberglass boat. I bought the boat and the engine about 3 years ago and just let it sit. Well, finally a couple of weeks ago I took it all apart, and restored everything. I also took the whole engine apart, changed the head gasket(cylinders had no scratches on it), rebuilt the fuel pump and the carb. Changed the points and spark plug wires. Also cleaned the whole lower unit, and everything looked good. Changed the water pump. Well, I finally put everything back together, and started the engine in a bucket. It started right up and ran perfect, I leaned the needle valve until the engine started dropping rpm, then i richened it back up, but i noticed that no mattter how much i would rich it, it wouldn't make a difference. It ran good at idle, so i went to the lake to try it. Well, i was pretty dissappointed. I know 40hp engines are small, but the boat which is about 600lbs would barely go. It wouldn't get on a plane, and the wind would feel like somone was just barely blowing in your face. So i was about to just go buy a new boat, when i came across a post here where a guy said his 90hp wouldn't have any power wide open either, and one of the suggestions was that he should make sure the fuel tank vent was open. That's when i felt really stupid. The vent on a plastic fuel tank was closed. I know that would keep the engine leaned out to the point where it wouldn't get power, right? I'm new at this and i don't really know what speeds to expect. I also was runing the engine for about an hour, and noticed that i barely used any fuel at all. I just wanted to double heck that leaving the fuel vent closed would do this. What speed should i expect from this engine, or should i just go and buy a new one? <br /><br /> Thanks a lot for the help in advance! Max
