hotpins300
Thread starter- Joined
- Jan 30, 2011
- 16
I have an older model 28 hp johnson and the carb has been rebuilt and I put in a new fuel system (tank, lines, primer) but I did not use marine fuel lines. I had some rubber hose lying around the yard and used that (it was unused). But when I try to start the motor, i check the color of the fuel and at some point from the tank to the motor it turns into a yellow/green and the engine will not fire. Is it the fuel line or something else?
