mikemerrill50
- Dec 3, 2005
- 84
I'm trying to figure out how my fuel system will be done on my bowrider. my boat has 5 stringers, and there is no room for a below-deck fuel tank. I have been told to account for 10% of your engine's hp in gph (15 gph for a 150hp motor). if i go with a 150 hp motor, i would want at least a 30 gallon tank. however, it would be hard to fit a 30 gal. in the rear of the boat under the rear seats near the bilge. also, i would want to be able to clean the bilge pump without removing the fuel tank. i am also worried about all that weight at the rear of the boat along with the motor, as i imagine this would cause serious weight imbalance and trim problems. what would you guys recommend? should i go with a multiple tank setup? if i do, i imagine i would need to get multiple fuel gauges, and that would get expensive and ugly. what have you guys done?<br /><br />thanks!
