Re: Fuel Tank Problems
remove the pickup assembly from the tank.remove the pickup tube and the fuel hose fitting. see if you can get air thru the fitting and the tank mount. Also,if you find a ball in there,remove it. This would be the anti syphon check valve, and it can cause much grief. Throw it as far as you can. Re-assemble,making sure there are no leaks in the pickup tube.When re-installing the hose fitting, use pipe dope or teflon tape on the threads.<br /><br />Good luck.. I hate thieves,don't you?
