drewpster
- Oct 17, 2006
- 2,059
Ok I came up with an idea on how to go about mounting my fuel tank and batteries to ballast the way I want it to. I want to mount the tank in the middle and the batteries to either side of the hull under the splashwell of my tri-hull. The problem I have is that the deck drain in the transom is in the traditional location in the middle/ bottom of the transom. If the tank is in the middle it will block access to the drain.
Here is what I want to do.
Moeller makes a 19 gallon tank that is longer than it is wide.
I want to build a shelf a few inches off the deck to mount this tank on. It will allow access to the drain under the tank. Then it will be a simple matter of mounting my battery boxes in front of the tank to either side. walla equal lateral ballast.
I have some concerns. First, I will have to make sure it will fit. Next I am concerned about elevating the weight of the full tank off the deck. It will be heavy when its full. You think maybe four inches or so would be to high? I am also concerned about the design of the tank itself. I assume the pickup in the tank drops in the middle. Is the engine going to starve for fuel as the boat rolls through turns when the fuel gets low?
This is all moot if the tape measure wont allow me to mount it this way. And I am not looking forward to building the shelf. But it is an answer.
What do you think?
What do you think?
