Re: Fuel Tank leak
Gary, A SR of that vintage may have an aluminum fuel tank. If so, and if you use it in saltwater, the tank may have lots of pockmarks and some pinholes. These are usually not repairable. Drain the tank via the gauge sender access hole and pull it for inspection. if it is as I described, you may replace it with a plastic tank of the same size. Normally the tank would be a stock item from Tiempo or Moeller.
