fuel tank capacity
troy new
I purchased a 1995 24' Suntracker Party barge and was wondering if someone knows the capacity of the fuel tank?
WaterDR
Re: fuel tank capacity
I was just thinking that. Just take WxLxH to calculate cubic feet and multiple by 7.5 and that will give you gallons.
jessp
I have always used W x L x H divided by 231
WaterDR
I cubic foot of water has 7.48 gallons....I use 7.5 for easier math in my head. If you are dividing by 231 than you are multiplying by inches and not feet. Either way works.
a1nowell
Look on the top of the tank, it is usually stamped on there somewhere.
Larry
wedge542
I purchased a 1995 24' Suntracker Party barge and was wondering if someone knows the capacity of the fuel tank?[/QUOTE If you got a gauge ck it for how much is showing, then fill it up,do a little math should get you capacity.
Outsider
That would work well if boat fuel gauges were accurate. They usually aren't ... :rolleyes:
samo_ott
Run it dry (with spare on board) and then fill it up.
Treker57
I have a 2000 Sun Tracker and the fuel tank is 26 gallons
