I have a 2004 200hp ficht, that, after repairs to the alternator system in the EMM by DFI, would start fairly easily. But, a few moments later, would be difficult to re-start. My mechanic put his laptop on it and told me the only message he got, although no alarm went off, was "low oil pressure." Eventually, we changed the oil pump (both the uptake and the injector pump). While going through these actions I noticed the fuel line from the gas tank, just in front of the primer was broken. So, based on what I've learned on these forums, the motor had to be sucking air. Good, I've changed the fuel line and she's still hard to start after the initial start. I decide to check the fuel and oil line going to the motor at the cowling. I remove the retaining plate at the cowling entrance and discover that the oil line too is broken and was only held together by the pressure from this flat metal plate. So now, I've got new hoses properly clamped,
Yet the hard starting after the initial start. Plus, the priming bulb gets real hard. If I disconnect the fuel line just beyond the in-line filter--the one outside the motor-- and squeeze the primer real hard, after a while fuel spurts out freely. What I've noticed also is: the priming sound coming from the fuel pump on the motor disappears at times. When that happens, the motor will only swing and not catch, hiccup or nothing! The sound comes back, weak at first, then stronger, she starts hiccupping and eventually starts, but runs rough and has to be accelerated frequently to run, or will stall.
Am I having a fuel-starving situation? Are there residual air pockets in the system that started the hard-starting problem to begin with and that are still hampering the operation of the motor? The forum's help on this matter will be greatly appreciated.
