Fuel starve problem i think
LTDan
Hail all,i have a 1.6 liter OMC in a 20<br />Sport Craft Fish Master.i have timed it with the<br />help of Iboat members.i ran her yesterday and the engine climed to 5000 rpms and shut down.<br />the S>L>O>W has been checked and is working.<br /> it has a water seperator on it,i replaced filter<br />yesterday also,fuel lines are new from tank to carb.this engine has VRO,any ideas are appreciate<br />also im putting smart Tabs on this boat comment<br />on this to if you have used them THANKS LTDan out
rickdb1boat
Re: Fuel starve problem i think
Does it re-start right away when this happens and will it run good below 5000 RPM's? Slow would have nothing to do with it shutting down completly. It would just drop back to 2500 or so RPM's..
LTDan
yes it will fire right back up,have to pump up ball though
jim dozier
Be ready when it starts to die and have someone pump the fuel bulb and see if it picks up again. If so its probably the fuel pump. You might also check the vent system on your fuel tank.
Daniel Beckman
Do you have an fuel restrict alarm mounted on that engine?
LTDan
the 1.6 liter has a fuel pump? i didnt see it in the manual.do you mean VRO pump.also if you get to bulb fast enough she will resume an idle
jim dozier
The VRO is a fuel pump, it also injects the oil but it is the fuel pump. Sounds like you need to fix it. I don't know on that particular engine whether it is better/cheaper to rebuild one or buy them new, someone on this board will tell you.
ezeke
I'm going back to the primer bulb going soft.<br /><br />If that is happening at the 5000 RPM range, then you may still have a problem there. <br /><br />Maybe sludge in the filter, air leak or clogged pickup in the tank. Possibly your tank vent isn't adequate.<br /><br />I can't think of another reason for you to have to re-prime.
LTDan
well it runs like a champ at 2200 rps tho, dont<br />fuel pumps just quit most of the time? i think<br />ill theck the vent first.and if i can check the pick up line in the tank.i guess if the vent is clear,and the pick up is clean must be the pump<br /> anything else you can think of,lay it on me<br /> thanks LTDan out
Daniel Beckman
Try to connect the fuel hose to a portable fuel tank. and see if that helps.
jim dozier
Fuel pumps on an outboard have flexible diaphragms. Usually these diaphragms get a small hole initially in them. As the hole becomes larger more air gets in or less fuel gets pumped. If pumping your bulb helps the engine there is something wrong with your fuel pump.
MDeVito
To check the vent problem: while running you can open your fuel filler cap and if the helps it is definently your vent line. If that does not help it could be your fuel pickup or there is debris in the tank. I had the same problem on my boat.
rickdb1boat
Could also be the anti-syphon valve at the top of the tank pick-up assembly. Take the fuel line loose at the engine and pump the bulb. That will tell you if you have a restiction from the motor to the tank if fuel does not come out.
