Fuel Sending Unit
Windjammer 7
If the fuel sending unit is working good, and the fuel gauge is working good, if I pulled the sending unit out of the tank and manually moved the
float, would'nt the gauge move accordingly??
achris
More fish than mountain goat
Re: Fuel Sending Unit
As long as the sender still had BOTH wires attached, yes....
Silvertip
Honorary Supreme Mariner
By removing it from the tank you essentially lose the ground connection. Ground the metal flange of the sender and it should work as you move the lever.
